F22Parts.com Header Gasket
    Hey i was checking out the website f22parts.com and i came accross this:
    It should solve the problem i'm having with trying to find a replacement gasket for my OBX SS header. It says it will fit all aftermarket headers. I was wondering if anyone has tried this or something similar and how well it performed. Thanks
    Arcadia Green Crew Member #9
    any feedback??
      i thought all you needed was just those two o ring crush gaskets.
        Not where the two pieces of the header meet on some aftermarket headers
          Yes, those too.
            Thanks for the pefect find. I was in need of one of those because of the ghetto gasket I had to make for my header. If you dont have it by the end of next week I know I will. I have the OBX as well.
            WHY ARE HURRICANES NAMED AFTER WOMEN? CUZ WHEN THEY CUM , THEY ARE WET AND WILD AND WHEN THEY LEAVE... THEY TAKE YOUR HOUSE, YOUR CAR AND YOUR MONEY....!
              I had to make the same ghetto gasket out of RTV Silicone. What did u use for the cat? Mine didnt come with a recess machined into it to use the stock honda gasket.
                I purchased a new catsound cat. But for the header I used a gasket from a another car that I found in yard I use to work with. I use the dremel to widen until it match the tubes then drilled new holes with a drill press. I can see a very small dark spot at on the header so I know it has a small leak.
                  What gasket did u modify and where did u get it at?
                    bump
