Best Performance Gas
    alright i would want to know which gas i would need to get the best performance out of my stock 92 accord engine
    regular
    premium
    supreme
    Everything done on this baby is all by me, NOT one thing done by a shop or store
    My myspace hit me up
    don't waste your money on gas on a low compression engine, well if its a f22, just stick to 87. 89, and 91 or 93 won't do much on f22ax
    Members Ride
      Performance gas? WTF do you also buy performance washer fluid?
      Use 87 octane, it is the best for our low compression engines.
      Gary A.K.A. Carter
      [sig killed by photobucket]
        completely stock, no mods, not even i/h/e, yea run mid-grade, i've noticed that lowest octane starts making the car weird, so mids will work, ur compression isnt high, ur not runnin boost, and ur not on the bottle so ur have absolutely no need for performance fuel. performance fuel is to fight detonation(sp??)
        "You don't have to be a Phi Beta Kappa to know not to strip-search a girl who is accused of stealing change,"
        I did gagoogity that girl. I gashmoigitied her gaflavity with my googis. And I am sorry.
          just run 87...no need to run premium if you dont need the extra octane, save a couple bucks here and there~
          justin
          My baby laying down some power...
          http://www.youtube.com/watch?v=kd_Q8HSIyqA
            If your car is tuned up, but you're running 89, go back to 87. It may take a tank or two before everything is totally smooth again. There's no power increase by using a higher octane fuel.
              lol. Defently no POWER IN BETTER GAS. 2nd time i heard that. Cuz someone i know. Thought that the better the gas the better the car will take off. LOL
              So for instant . Diesel. it's gonna give u 10-15 increase in hp . LOL
              91 Accord EX (Fresh Look STOCK)
              BIG PLANS on THIS!!!!
              9-12-05 - On
                it only makes a difference if you have higher compression or if you have done some mods.
                although, when i had my f22a, i did notice I got better gas mileage with mid grade gas. thta was due to the better burn, but it was only a couple miles more per gallon, not really worth the extra 10cents per gallon imo.
                  It will do nothing, regular is fine.
                  Octane is a rating that is given to gasoline on its ability to prevent detonation.
                    I used to run 87, but since the gas prices are down, I advanced my timing even more and run 89 now.
                      i experience better MPG using 89 from Chervon...i always use chrevon since its close to my house...
                        Use 87/89. I ran 89 on my a6. POintless to go any higher. And no performance gains from gas on a stock engine.
                          i run 91.....with my headswap
                            what leval octane should we use if we got an h22?
                              91 also when you advance your timing quite a bit. Helps the pinging..
