keep messing up tps sensors
    Ok i don't know what the deal is but whenever i get on it in boost some times i lose a little control in 1st gear and the car will slip to round 6800 7k ish rpms, it seems like almost every time it does this i end up throwing a tps code and then keep throwing it from then on until i chage the tps. this is the second one that has done this, curious if any one else is having this same problem using a chiped ecu? will play with my tps settins to see if it helps.
    You try setting it? Whats your TPS Setting.
