Yo guys...check out this H22 plenum, it's ridiculous
    Originally posted by immeraufdemhund
    shoot i dont know if i woulda stopped at just the whole plenum thing. I think i woulda just made the whole IM. I guess i'd cut it just before the Fuel injectors and balloon out with the throttle pointing towards hood in the middle of the runners. sho far then just add a reverse cowl and hook it up accordingly. that would, IMO, fix the outside cylinders from starving, and would create a capacitor like area for when you need more air.
    werd, port that mani like crazy.
    idk...this vs. ITB's
    both seem espensive
    I <3 G60.
      both seem espensive
      That plenum couldn't have cost more than $50 to make, and that's a generous estimate. And even if you made the whole thing down to the flange it wouldn't cost that much, although it would be a lot harder to work with. I really wonder how that thing would perform on the street.
      Originally posted by lordoja
        I agree cheap stuff for a fabricator.
        If it didn't lose any low end, boosted power to over 260 in the top end, clears the stock hood, and cost not a lot to make, how do you suppose it performs? I bet it would be a beast.
        It might be a little loud though, because square walls and flat sides are perfect for sound resonance, but it probably isn't louder than ITB's.
        You would probably need vacuum nipples on a DD though.
          so what if i were to design a box that sits on top of the runners.
          but cut out a hole out large enoguh to fit a decent size TB, so the TB is pointing upwards....custom fit a scoop to run a square filter on it and get some kind of hood scoop or aftermarket carbon fiber hood that would allow airflow to the filter?
          I <3 G60.
            You would be...creative. Square isn't necessarily the best for airflow though.
              :o
              i must use my engineering skills to develop the proper mechanism which would allow optimul yet adequete airflow to benefit toeque and hoprepower.
              I <3 G60.
                :o
                abso-freakin-lutley! And that's the bottom line because Big Daddy Don Garlits said so.
                LOL.
                  i think it would be benifitial to costom make runners in side of that so that each lower runner got the same amount of air....ud have to work around the fact that a thoutle body is circle tho cuz if the runners were evenly spaced the ones on the top and bottom will get less air ...no what im sayin?
                  Old Ride-New Ride
                    A picture would help. I kinda get what you are saying though...
                      hah i dont know y im going this far to explane my self but w/e i have nothing else to do
                      What i mean is u can tell that since the tb is circle the top and bottom are getting less air .....u can tell becuase there is more gray area which = less space for air to get in...what you would have to do is make the two middle runners a little a bit tighter or smaller
                      buttttt then u have to deal w/ the fact that in the intake theres more air concentrated in the middle of the intake path so that means even less air getting to the top and bottom.....and this can be sumwhat fixed by using the the idea that the AEM v2 uses in which a large tube goes into a smaller tube so the middle of the intake charge is cramed evenly in to the pipe right befor the manifold and the runners concept
                      PLEASE LET IT BE KNOWN THESE ARE JUST MY THEORIES. IM NOT TRYING TO PASS THEM OFF AS FACTS
                      i also dont really belive that the v2 really works that well but the theroy seems pretty true
                      feel free too prove eather of these theories wrong....just please READ MY PREVIOS POST FIRST
                      Old Ride-New Ride
