2 headgaskets?
    2 headgaskets?
    I'm having a problem finding a headgasket to match what I need. The Cometic one is way too thick and to get my desired compression I would have to mill the head and spend even more money there but the factory .026 gasket won't clear my pistons. Can I use 2 headgaskets together? If you don't KNOW, don't answer. I've built plenty of engines it's just that I've never needed to run 2 gaskets so I never knew to ask someone. The only thing I'm seeing will be a leak. I can't fuse them togther before the install with some kind of adhesive becuase that would cause uneven thickness. If not then I'll have to buy the Cometic and mill.
    No, ive heard of people using double layer headgasket, even triple layer just for compression's sake...
    Take a look at Mr.Gasket, i believe they make steel headgaskets...another alternative...
    Im sure some company can make a custom one...of course $$
    I would hate to mill the head if there is no real need...but hey, there is no price for perfection right?
    1990 Accord Lx F22a1(Daily) SOLD - will be missed
      This might sound retarded and might not work but can you cut down the cometic a lil? Dunno wont work most likely. Some aftermarket people run multilayer gaskets but they are pretty thick. What type of thickness are you lookin for? And how far is the Cometic off by?
