A6 Manifold on a SOHC VTEC Head?
    hey guys. i'm in the works of putting an F22A6 intake manifold on my F22A1. But i also plan on putting on a SOHC VTEC (F22B1) head sometime in the future. my question is do they fit together very well (w/o major modification)? and if so, would the P0A ECU for the VTEC also control the butterfly valves?
    thanx
    i HEARD that people with the f22b engines put a h22 or h23 top end manifold on theirs..and a h22 or 23 throttle body...but im nto sure
    so your doing the swap too? damnit i gotta hurry polishing mine!!! hahaha i have to be the first !! hahahalol jk!!
    Retro!
    Hater
      Nope, wont work.
        bolt pattern and ports probably don't line up...if u still wanna add the 16 mani it wouldn't be all that much of a loss anyways because theres still ppl that will pay $100+ for it a couple of years from now.
          ok cool. thanx. so the mani will only fit on F22AX heads.
          i guess you cant have the extra valves and VTEC
          yea, accordztech, the A6 intake swap is relatively easy and cheap. this swap should catch on quickly
            man it caught on very quick! i have to hurry and port and polish mine and put it in next monday...
            Retro!
            Hater
              since i'm putting mine on an A1, do i need any additional parts (hoses, wiring, etc.)? or could i use existing wires? i'm guessing i at least need one hose for the diaphragm..
                i want pix of the p&p...if i'd had my digi cam at the time of install i would have taken pix
                  you can literally just slap this manifold on the engine...since u have an a1 engine the iab's aren't going to close in the first place they'll always be open unless u have a a6 ecu to control them
                    i heard that you could hook up a switch so that you could open them whenever... is this just a soldering job that i could do?
