Emissions with UD
    Emissions with UD
    Alright, I got a question for those running built motors or do emissions with a chipped ecu with uberdata, besides Iamanonymous, who else has passed running uberdata? Reason I'm asking, is because last time I took emissions, I put the pt6 back in, disconnected the charges pipes, and put the stock injectors back in. Well somehow one of my stock injectors failed awhile back(long story, and I don't know how it happened), so I can't put the stock ecu and injectors back in. So basically I'm stuck with uberdata to pass emissions, any tricks that will help?
    Shift_BOOST
    BOOM!
    I've got an h23 injector you can have. Otherwise you can still disconnect your charge pipes, and try it. If it runs to rich you have two options, create a vaccuum leak to add more air (Disconnect the brake booster line) or have a constant 45 vacuum on the fpr to lean it out. If nox is to high retard the timing 5-8 degrees.
    Thats about all I can think of. Good luck. L8r
    Turbo H23a3 build has begun
    01-01-2019
