Spark Plugs READ THIS!
    Just to let everyone know. I put new spark plug wires in the new CB7 I got, and there is a VERY big difference in pull. If you have not replaced them for a while go out and do it! I put in Bosch Plugs!
    holly shit man, imagine if you did a full tune up!
      NGK plugs are highly recommended by many
        yup NGK's are my choice! nothing fancy about it.
          my engine doesn't like NGK....either bosch or denzo for me running bosch platinum 4's for about 50k miles and still looking good. so what does that tell ya?
          My members ride thread
            Autolite's
            Anyway, I used to run autolites all the time when on my fmu/missing link cuz they fouled once a week. Now that I'm tuned on uberdata I run ngk's and have been on the same set for like 2 months, its a freakin record for me. L8r
            Turbo H23a3 build has begun
            01-01-2019
              how long were your old wires in there?
                Autolites...lol...my friend used to change spark plugs everytime he did an oil change...with Autolites...i liked his theory on why he did that...
                Changing spark plugs every 40k`ish is a good idea, maybe even less...new spark plugs, better spark, better explosions for pistons to move...
                New wires is always a good idea...better conductivity flow...
                :::How do you check if you guys have stock spark plug wires?:::
                wipe the crust & oil off your stock black wires...you will see the born on date...1990, 1991 etc... in small red numbers...if that's the case...CHANGE THEM~!!
                1990 Accord Lx F22a1(Daily) SOLD - will be missed
                  i have a big feeling that my plug wires are original. i want to get some NGK wires to replace em with. i replaced the plugs not too long ago with NGKs.
                  "the J32a2 should be considered one of Honda's masterpieces..." Honda Tuning, July 2006
                    As long as the original wires are intact and the measured resistance is in spec, there won't be any problem with running the originals.
                    Sorry, but I used to have $100 set of MSDs and there was absolutely no difference (not even gas mileage) switching between the 2. That is with 213,000 miles.
                      Very true, if you measure the resistance of the wires (At operating temp, it will vary) and they check out ok, keep them. L8r
                      01-01-2019
                        I bought the car used, so I have no idea how old they were. I will get the NKGs fo sho then! I have also done the fuel filter, oil/filter change, MAJOR clean out, etc. etc...
                          When i bough it from this white man...it already has NGK plug and Autolite wires...I guess my wires are reall old..gona replace em soon wid NGK yay..
                          MY 1n2 CB7
                            i would recommend honda oe replacment parts from your local dealer only for a tune up. ive seen alot of hondas with wack tune ups. alot of them not running due to cheap tune up parts. champion spark plugs are some of the worst plugs you can put in a honda.
                            http://www.cb7tuner.com/vbb/showthread.php?t=22013
                            cb7tuner.com Cleveland division
                              that is key
