Originally posted by hemlockz
Also, I think between all three of us we can get a good 272 map made, besides I need to get going on this hardcore since the April 21-23 North Carolina meet is coming and I at least want to roll down there with a decent street tune. If we can get a decent street tune map made soon enough, I can get my car dynoed before the NC meet and bring the dyno graph down for a final street tune. Sound good? I have my Zeitronix wideband hooked up as of last night and it works. I just didn't get much time last night to datalog, but that's the plan for this weekend.
BTW MRX, I'm getting that vacuum T-fitting right after work so hopefully the IABs and FPR will be functioning normally like they should. Then, I can dial in the idle via adjustment screw to like stock (if the cam likes it), set ignition timing based on whatever idle RPM I settle at. Then, run another datalog at idle, then do the neutral RPM revs and note AFR at certain RPM points. Finally, go on the 3rd gear pull run and datalog for you and we can look at the fuel maps, etc.
