Fuel Injectors & Performance Builds
    Random thought to strike up a conversion...
    I know many of you are building up DSM turbo setups on F22's etc and buying used DSM injectors from who knows where. Even naturally aspirated people get used larger injectors from who knows where. I haven't seen too many purchase new ones.
    Anyhow, how many of you doing a performance build actually stopped to think...you know, I'm installing USED injectors into my PERFORMANCE build. Maybe I should have them cleaned and flow-balanced before installing them and on top of it, tuning my setup with possibly dirty, unbalanced injectors that are robbing me of power I should be making.
    Thoughts?!?!
    www.cruzinperformance.com > Cleans and flow-balances injectors for hella cheap. I'm sending both my F22 and H22 injectors there for both my projects.
    You belong on Honda-Tech
      another great and informative write-up
      i personally didn't clean and flow test my injectors; the shop took care of that for me, but definetely something not to forget about when building up a motor, whether it'd be for a NA or boosted application.
      5.6L V8 32V DOHC
      JDM HERITAGE - US BUILT
        injectors really dont need to9 be cleaned thgat much i just dipped em in gas
          its not the outside that needs to be cleaned its the inside. Dirty insides make for bad spray patterns and in some cases less fuel being delivered.
          I bought mine local from a DSM friend. 2 of mine are new, the other two he assured me were perfectly fine also and would replace them if necessary. I never expected my setup to last this long and at the time of install i didn't have an extra $100 to get them cleaned with. But when i find some evo injectors i'll be sure to clean and balance them.
            Bro, it's only $48 + shipping (4 injectors) to get this done at the link I specified in the first post.
              thats not bad, local at the time tho it was $25 an injector
                Yea, it's not bad at all. In fact, they are in Michigan!!
