Who has tuned their vacuum map?
    This is to know if you get a better gas mileage... if yes can you share your experience and maybe share you maps?
    I'm not exactly sure how to respond to this...are you talking about stock for stock? If your practically stock then you won't need to touch it at all cause the stock ecu's are pretty well setup from the factory. Trying to be better than the stock ecu is HARD.
    To answer your question tho, yes i have tuned the vac map on the f22 and its gets similar gas mileage, i think its within 1 mpg or less
      its not for for going in a stock application... i just want a map that is able to run properly... cause i want to focus on the boost section, i'd like to have a uberdata f22 stock map... but i know they don't really exist, you have to start with a p06 map then you play with it to adjust here and there...
      i found one, i think it's from you but i dont remeber the name of the file, its on my laptop...
        PM me
