i just ordered a new header catback exhaust system, and i still have some extra money to spend i found a aem pulley set on ebay real cheap. is the pulley and underdrive pulley easy to install or does it require some special tools?? i need a response asap so i can get my cb7 going fast. thanks
pulley set question
Originally posted by Tcb7accordsi just ordered a new header catback exhaust system, and i still have some extra money to spend i found a aem pulley set on ebay real cheap. is the pulley and underdrive pulley easy to install or does it require some special tools?? i need a response asap so i can get my cb7 going fast. thanks]
go with UR pulley...def one of the best out there......there is your power right there. as to install.....real straightforward and easy if u have the right tools. entire pulley install should only take about 2 hrs includingh the adjusting of the belts and that is with the crank bult being a pain in the arse lol. as to the underdrive pulley decreasing internal power lol well when u underdrive yes the alternator will put out less power (dimming of the lights at idle) that why u upgrade your alternator! but there is NO proven negative effects caused by underdrive pulleys....just alot of myths and fools complaining.
as to the exhaust making the car fast....it will.....in a sense....i mean it can free up on average 15hp for full exhaust system 12-20hp have been realized.....it the additive effects of each mod that in turn make the car "faster".
