I have the copper gaskets already, I think my leak is either from stretch headbolts, or a warped head. When I first finished putting the motor together I didn't have this problem, so it's not from the gasket. I'm going to pull it and check the straightness, and install ARP head studs. That's what I get for rushing to get the car running and using the stock radiator for dyno tuning... A lot of people have issues with the map sensor when converting from 1.11-1.19 you need to re-establish it or it will use TPS as load. That's what would cause the problem you described above.
my oilpump exloded
Originally posted by 93accordI have the copper gaskets already, I think my leak is either from stretch headbolts, or a warped head. When I first finished putting the motor together I didn't have this problem, so it's not from the gasket. I'm going to pull it and check the straightness, and install ARP head studs. That's what I get for rushing to get the car running and using the stock radiator for dyno tuning... A lot of people have issues with the map sensor when converting from 1.11-1.19 you need to re-establish it or it will use TPS as load. That's what would cause the problem you described above.
make sure you tighten down the studs themselves very well to make sure they are completely bottomed out... I went over mine multiple times and 1 actually turned more... I think it was the larger center one...12.5 at 114.6mph 15psi
11.7 and 11.5 20.5psi
F22a1
60-1 td06h turbo
Darton mid sleeves
85.5 wiseco 8.8:1 forged pistons
Crower pro billet rods
Custom ported head.
KMS valves
F23 headgasket
ARP H23 headstuds
H23 upper intake manifold
F22a6 lower intake manifold
Intake manifold is gutted
AEM EMS 1040u
FIC 850cc injectors
Walbro 255 pump
H23 manual trans
Prelude shifter assembly
Forbidden short throw
Nitrous Express Kit installed, never used on this motor
http://www.unorthodoxracing.com/faq_pulleys.html
Scroll down and read what is says about oil pumps. Just some food for thought.
Friend of mine linked me to this (thanks Mike).
UR sells only 2 versions of their crank pullies for the 90-93 Accords (i.e. Tuner S and Ultra S).
Tuner S is about 2 lbs.
Ultra S is about 1lb.
They also said the Tuner S is about 70% of the performance of the Ultra S when it comes to power gains.
The stock crank pulley is about 5.5 - 6.5 lbs, so there are the differences.Last edited by HondaFan81; 12-15-2005, 12:07 PM.
lol people can't own up to their own mistakes so the parts are the first to blame! i'll admit i have done that once or twice. yea if u read the UR site and a few other underdrive pulley articles.....it totaly pwns those that say the underdrive pullies cause damage. lol lmao and and and that ridiculous site that has a "test regarding the vibrations from the pulley" is sooo stupid.....the experiment was soooo severely flawed i almost shit myself. ugh sad very sad.
Well boys, we lost a good deal with www.dh-racing.com in having chance to get $125 crank pulley that like weighs 6oz from Dave. He's not selling them anymore because of all the comments like this he's had to deal with. This is a helluva deal compared to UR products.
My friends have UD pulleys and ther cars are fine so far havent heard bout oil pumps goin to shit yet. I recommend not buying Ebay UD pulleys (Bomz) since i had one on my car before. They work well but when you try to take them off it takes forever which is why i went back to OEM.
