ebay 1.45 lbs crank pulleys
    i got one. works great and the engine works alot better. the oem one is heavy as hell.
    miss my turbo cb7
      Originally posted by KeelesKustome
      just remember the advertisers get paid millions to hype up their products.. and magazines also get paid bundlles by their advertisers to help fill our heads with this makes hp jokes.
      yes sometimes a light weight crank pulley can be good,, it says it may cause what 5 horse power.. well lets see some dyno charts..
      what normally happens is in one specific area the car might gain 5 exta ponies then drop back off... and thus also creating the rest of your powerband to suffer...
      example most gsr motors from the factory have out dynoed those that got a fuel pressure regulator, light weight pulleys light weight flywheel intake headers, exhaust..etc small bolt ons... why..
      well obviously honda teck pulled as much power as they possibly could out of this car from the start.
      yes lighter parts will let you rev higher,, but you also have to rev higher to launch at the same controlled speed that i would be launching at....
      their are many pros and cons.. just research
      great points and very realistic, however, at the same time many tuners are willing to sacrifice power at levels below the upper rpm that are used for racing.
