i have a 92 accord lx black. i want to figure out what version of the F22A i have.... because theirs many different ones that im guessing... id appreciate any way i could find out which one i got especially from fizzbob or anyone who knows alot bout engines, even u ztech might know
What Type of engine to i have. (F22a1, F22a4,f22a3?)?
By the way, exactly what is the diff between a1, a4 and a6... as far as I know difference between a1 and a4 is only ecu, tb, and exhuast manifold and that the a6 only has a lil larger diameter exhaust manifold. I've also heard an unconfirmed rumor that a6's had a lil bit different cam too. Is my knowledge on this correct???-1991 Accord DX-
Ractive SuperFlow Intake w/ Heatshield Filter
Pacesetters Header
Ractive Hi-Flo Cat
Ractive Muffler
FOR SALE****
17" Enkei Shoguns (no tires)
Accord Wagon club articleVisit us at http://www.valleyspecialists.com for all of your Honda and Acura service needs!
i think its the f22a1 with less HP and torque than the a4.
i think f22a1 has 125 hp or less and 130 torque..
i think f22a4 has 130 hp and 142 torque....fizz pointed it out in a thread to me one time...
i have the f22a4..What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
yea, the engine specs you mentioned about sound right, an the f22a6 is 140 hp, 142 lb-ft torq.
However, the diff between f22a1 and f22a4 is 5 hp, so I'm guessing it's just the exhaust header design that's diff??
then I think u guyz said the diff between f22a4 and f22a6 is the intake manifold design.
this correct? always wondered. I have two accords one with f22a4 & f22a6
Here's the differences
F22A1 - exhaust manifold is 4-1 and all jumbled together with small pipe
F22A4- a 4-2-1 manifold design which frees up the extra 5 hp
F22A6- Same 4-2-1 exhaust manifold (may have slight differences but bolt up exactly the same), but includes a nicer intake manifold which has a secondary set of butterfly valves that allow more air to be ingested and priduce higher gains. Also in the intake filter box, there's a little flap that opens and allows more air in under certain conditions. If you install an intake, you bypass that, but for a stock air box, it will help produce gains. Between those is where the extra 10 hp comes in.
