go with the h then build it for boost But keep the f in there for now as a daily beater then when its time for boost, boost it with the h more power guaranteed with torque
Opinion: Turbo or All Motor?
If you're going to boost it there's no reason to do a swap. I'd rather build and boost an F22 than swap, build, and boost an H22. Simply because you can reach you performance goals with the F22, there is no reason to swap.
With forged pistons, rods, a block guard, a good turbo, and some good tuning there's no reason you shouldn't be able to reach 350 hp, then you'll have no problem running 12'sH.S.A.E.
90 CRX Si - gutted, caged, Bisi F2d kit, close ratio LSD trans, F22A6 - under construction
99 civic LX - y8 head and trans, lowered, blowing cold AC, and getting 35mpg.
Originally posted by hatchninjaIf you're going to boost it there's no reason to do a swap. I'd rather build and boost an F22 than swap, build, and boost an H22. Simply because you can reach you performance goals with the F22, there is no reason to swap.
With forged pistons, rods, a block guard, a good turbo, and some good tuning there's no reason you shouldn't be able to reach 350 hp, then you'll have no problem running 12'sR.I.P. Landon Hilburn 06-27-08
Soon to enter the family.
CG Coupe!
92 Accord EX Sedan (Newest project)
Members ride thread 92 EX Sedan
Members ride thread old 91 LX Coupe
