Using H22 crankshaft.. Have questions!
    Hey guys I REALLY need information on this.
    I know using the H22 crank lengthens the stroke, which is what I am looking for. So I need to know whether or not I have to space the head or not?
    Please give me some helpful information on this.
    ALSO... If anyone knows of a thread on here that is helpful post it. I used the search but came up with USELESS info.
    "you can catch me swoopin 4G coupin switchin lanes" haha haha.
    1993 SE coupe drag car ahoy!
    1992 EX coupe 5 spd **sold **
    Did work for: jhoff_cb7
    not to thread jack or sound newbish, but I didn't know it had a longer stroke, but I did know the H series engines have a bigger bore, so how could it have a bigger bore, longer stroke, and the same 2.2L displacement?
      its the size of the block that determines the displacement. The bore and stroke determine more of the HP and TQ. Hope that helps
      Also yes the stroke on the F22 is shorter than that of the H22
        huh? no its (bore area) x (stroke) = displacement
        FA1
        355
          Bore
          H22A4 Block = 87mm/3.425
          H22A block = 87mm/3.425
          H23A block = 87mm/3.425
          H23A1 block = 87mm/3.425
          F22 block = 85mm/3.346
          F23 block = 86mm/3.385
          F20B = 85mm/3.346
          Note:
          Due to various available piston diameters (A/B) actual bore diameter may vary
          Rods
          Length
          H22A4 = 5.633
          H22A = 5.633
          H23A = 5.572
          H23A1 = 5.572
          F22 = 5.572
          F23 = 5.551
          F20B = 5.709
          Crankshafts
          Stroke
          H22A4 = 90.7mm/3.570
          H22A = 90.7mm/3.570
          H23A = 95mm/3.740
          H23A1 = 95mm/3.740
          F22 = 95mm/3.740
          F23 = 97mm/3.818
          F20B = 88mm/3.464
          http://www.honda-tech.com/zerothread?id=1232811
          the h22 in fact has a larger bore . . . but shorter stroke.
          -Mark-
          CB7
          CD5
          And if i could swim I'd swim out to you in the ocean
          Swim out to where you were floating in the dark.
            OK OK OK WAIT!!!!!!! why the hell did everyone say that the H22 cranks lengthened the stroke?
              theres a mag article about guy that buildt an f22 using h22 crankshaft and if im not mistaken he used h23 rods? and h22 pistons. he called it rev friendly sohc. i dont noe which mag or were it's at but as soon as i find it i'll post it up.
                Yeah the shorter H22 crank is more rev friendly, but with F22 stuff it will lose compression. You should get the H22 slugs and rods too...what are your plans exactly?
                Originally posted by lordoja
                  H22 lengthens the stroke when compared to a F20a, if that's what you're comparing it to. However, it does not when compared to F22
                  F20a = 88mm stroke
                  H22 = 90.7mm stroke
                  F22 = 95mm stroke
                    so then a h22 crankshaft using h23 rods and low comp pistons would make a sick turbo motor right?? im guessing the comp. ratio would be something like 8.0 to 1 right??
                    i found out who the guy is that stuffed a h22 crank into his f22a1.. his name's bisi... and he's a pro drag racer. he's registered on h-t but he's never on.. alot of the guys at honda society seem to noe him personally, his cars running 390 whp, with a f22a1/ h22 crank and somekind of internals, but he's ALL MOTOR!! bisimoto.com
                      yeah, bisi is a genious man, hes done so many things with the F series engine that no one thought was possible.
                        i was bored, and i did some math, and if im wrong in something, can some pls correct me? thx
                        what i did was figure out the rod ratio of the combination of the h22 stroke and the h23 rods.
                        using the formula rod length/stroke i got:
                        141.5288/90.7= ~1.56
                        now, the ideal r/s ratio is 1.75, which when an engines r/s is close to that, it will be a able to rev better. so yes, the combination of the h22 crank and the h23 rods will allow the f22 to rev higher, but in the process, since we decreased(destroked) the engine, we lose low end power(torque).
                        i just felt like doing this to let everyone know that yes it will work, and how it will work, that way ppl can stop making threads about this.
                        if im wrong anywhere, someone pls correct me. thx
                        jdmcord aka jose
                          Not too much displacement though...it's like 60cc. The F22's really like an F21 stock...
                            jdmcord aka jose
                            You're right in your math, but who said ideal rod ratio is 1.75?? It all depends on what your application is and how you want your engine to perform.
                              F22ax is 2156.31 cc (nominal)
