what is it i need some info
Manual Valve Body
Your transmission is equipped with what we call a valve body. The one installed by the factory is an automatic valve body. That is why manual shifting it will destroy it quickly. Manual shifting in an auto valve body causes sudden changes in pressure which cause the tranny to shift and jerk during shifts. A manual valve body is built to handle the sudden shifts. It will shift your transmission the same way the TCU would do it so it will not wear out the internals in your tranny. More or less. I will clarify this later, I am at work right now.
wow, thanks for updating this i forgot all about this.
Here is a link.
To keep your tranny and you happy.
The TCU modifyer.
Also, check out that PTS kit. TRUST ME ITS WORTH IT!!!! My friend used it on an Integra he had a couple years back. It was so awesome people swore it was stick shift, until they found out the shocking truth. It worth it if you are serious about your performance.
Originally posted by AcclipseH23wow, thanks for updating this i forgot all about this.
Here is a link.
The TCU modifyer.
