For those of you who thought this could not be done!!!!!!! I was saying in my member's ride thread, that I visualized that the Megan DP can fit the CB7. I got the 3 inch stainless steel from the 2g GST. To get this on you will need to do some major mods tho. Here is the list:
Cut the front crossmember up to accept the DP's size
Remove about half your existing exhaust
Thermo wrap the DP around the oil pan
LIGHTLY massage the oil pan around where the DP makes contact
Grind down block webbing ( f you did this to fit the turbo and there is plenty of room then dont worry about this)
After this I bought some pipe and flange off ebay and I welded up the exhaust and bolted it on. You pretty much need just the rest of your old exhaust to copy the pattern.
NOTE: Megan DP eliminates the cat. You can weld it in if you wish. I have a Carsound cat way in the middle of the car. It does not seem to slow the flow down but i may remove it because the car isn't loud at all.
And just like that the DP is in and its at home. Pics will come when I get the digicam. I did this a while ago but I wanted to make sure it does not leak.
P.S. On the scale of difficulty this is gets 4 wrenches. It requires some serious tools so its not for everyone. (I watch too much TRUCKS! with Stacy David <--my idol)
