f22a 101
    Plus going all motor won't require new injectors or drilling your IM...and from what I know NO2 is kind of a pain to use safely. You'd need everything outside of the turbo to use a 50/75 shot on a regular basis without worrying about running too lean and blowing up your motor...not worth it IMO...
    Originally posted by lordoja
      You have to drill your IM? I never heard of that one...
      My official vouch thread!
      Updated!!! --> My official turbo progress thread
        save up more and hold off for a swap
          I thought you had to tap the IM to run the lines/injectors. I know they have kits that go right into the intake filter...oh well.
            Like I said, you won't get much from a milled head. Something like 20HP right? An A6 manifold and cam alone are worth 10.
            If I get a used head and ship it out, that is definitly an option, but like it was mentioned, I have to ship it somewhere. For what if would cost to pick up a head from a junkyard, ship it, wait for it to get back, and then swap it, I am looking at a couple hundred bucks at least. I can pick up COMPLETE A6 mani's for around $100 in Phoenix all day long (I can't say the same about machine shops), and I have 1/2 the HP right there (with the cam). Less work, 1/5 the cost, less waiting and I get a decent power gain. Then add a good exhaust system and I will just about equal your output with my setup. Don't forget, you have to include the cost of adding the exhaust etc after you swap your head. I can have an exhaust made for less than $250 with a decent muffler, stainless mandrel bent piping and a resonator. So for a little less money, I have a car that is pretty much as fast, sounds the way I want, costs less, and took less time/effort to build.
            That isn't to say that milling the head isn't an option, but that isn't where I would start. It would be great later on (if convenient to do so), or with a built N/A motor, but not on a mostly stock engine.
            Nitrous is a very feasible option, but most people prefer mods that are going to work all the time and aren't going to keep costing them money. Dollar for HP, Nitrous is impossible to beat.
              But a compression bump will do more than just add HP...it'll make your throttle more responsive and do a hell of a lot for your gas mileage. And as far as the A6 stuff, what if you already have an A6 engine? I'd rather bypass the A6 upgrade and go with a cam. I wish the H22 IM fit our cars...
                Originally posted by alb_accord
                i
                $250x2<<<< well for that kind of money u can go to the junk jard and pic a 5th gen ex engine lol....
                and I'll take that engine on with my stock F22a4 motor and make it clear you just wasted $250x2 for nothing...it's not worth it even for the $500 unless your current engine is running like crap
                  cheap, but increased performance from stock suggestions ...
                  Maintenance, get engine running right...then...
                  Intake, bore throttle body, port intake manifold, regrind cam, off-shelf-header, crush-bent exhaust to a muffler of choice or some cheap exhaust system that's like 2.25" or so. At least take the time and set your cam timing to optimal and ignition timing for the most reliable performance, if you need to adjust your air/fuel ratio get a fuel pressure regulator.
                  A/C & P/S removal are options as is weight reduction.
                    A/C and P/S are good to do...you'll prob. lose a little traction though from the weight loss (isn't A/C really heavy)? I'd trim weight from the rear before the front...
                    But yea all that stuff sounds about right, especially with a better clutch/short shifter. My clutch is slipping...if it wasn't my car would be in a whole other league of performance. It takes like 2 seconds to catch 2nd gear if I'm racing. I've seen basically stock F22 CB's chirp 2nd...we've got power. 15's are possible with an F22.
                      true that........
                      well i think we prety much covered all the hp upgrades to the f22 for $250 or more. lol
                      hopefully some of the new comers will put all of this information into good use...
                        Originally posted by 92HondaEX
                        When did I say "forged internals"?
                        omg i mistook hi cr pistons for forged pistons, please dont kill me.
                        But a compression bump will do more than just add HP...it'll make your throttle more responsive and do a hell of a lot for your gas mileage. I wish the H22 IM fit our cars...
                        some knows what im talking about. and u can use the h23 mani too. thats what im runing right now on my sohc
                            That's what I was going to mention too. The H23/F22B manifolds are pretty much identical to the H22 manifold, only they bolt up to an F22A.
                            Every mod listed in this post is going to improve throttle response/drivability. It is a given consequence of more power.
                              ok guys
                              now i am working on a a6 engine.... he gona take the head off so we can sent the camshaft to delta etc...
                              and we are gona mill the head
                              now a while back i been told not to mill the head more than .45....
                              does anyone here done any work on the f22 head???? how much did u guys mill the head?
                                I thought the H22 had a single-runner IM...hmm...
