I have been researching this and havn't found out much of anything. I know it can be done, because ive some cars with it done. my problem is no one is saying what it took to do it. I have a complete f22a, i want to put a h22a head on it, but ive heard the h23 is easier. I would like to know which is better. Im thinking the h22 would be harder but it doesn't matter. If it can be done and put more power down than the h23 then ill get it done. I need to know exactly what parts to get and what hole to block off to make this work. If anyone has done this or knows a site that has a step by step of this let me know, thanks. Aslo after its built , its going to be turbo, so if one head is better for turbo i would like to know.
H series head on f22a1 block= Need Help
Originally posted by g-wagonh22 revs higher....... so its better to go with h23...... unless you want vtec for a little while to you spin a bearing or something...
The real H would definitely make more power. If you put the H head on as is w/no internal work you're gonna lose compression, and if you rev it up to 7400 rpm you're gonna spin a bearing.
If you wanna make H22-ish power, or at least run H22-ish numbers, here's what you should do: get an H23 head & some Crower street cams, and find a good shop to weld some aluminum on the area around the valves...that'll give you some more compression, maybe bump it up to 9.5:1 or so, and seal the 2mm extra bore on the head. Just slapping an 87mm head on an 85mm block will be disappointing at best.
Originally posted by lordojaim with you on that one bro! aint nothing beat free food and drinks any day of the week, even if its at a funeral
If you wanna make H22-ish power, or at least run H22-ish numbers, here's what you should do: get an H23 head & some Crower street cams, and find a good shop to weld some aluminum on the area around the valves...that'll give you some more compression, maybe bump it up to 9.5:1 or so, and seal the 2mm extra bore on the head. Just slapping an 87mm head on an 85mm block will be disappointing at best, and it will be even moreso when you can't get the most power from the head with the slow/unbalanced bottom end.
