cai install question
    hey I picked up a used AEM cold air intake and I was looking at the diy post on how to install it. It mentioned to stuff some AEM foam into one of the vac lines . Can Any type of foam ( like some off of an atv air filter) be used?
    sorry if this is posted in the wrong fourm.
    anyone?
      You just have to plug it bro..
      http://www.FLAccords.com
        So I plug both lines?
          for aem intake
          on 90-93 models you have to install the peice of foam on the starting boost valve located on the end of the upper intake manifold(opposite end throttle body). unplug the vac line and remove. the connection on the starting valve is where you put the foam. use zip tie to secure. just use foam that will allow enough air to pass through, otherwise itll have trouble starting. on the 94-97 accord you have to plug the vac line since their is no starting boost valve. the end of intake has an air boost valve where all the accessories like power steering and fuel pump regualtor vacuum source. on 94-95 models use foam on intake manifold where fuel injection air boost valve connects tof fuel rail.
          goodluck
            thanks "x" The used aem did not come with any foam , What type of foam should I use? I know it is a lame question so sorry in addvance
              any foam
              just use foam thatt isnt as dense like a foam mattress, it has to allow air to get in to allow easier starting,but the foam also prevents dirt from getting in. the vac line you disconnect is garbage you can toss it. thnk it connect starting valve to throttle body. just plug throttl body bung when you disconect it
                very cool thanks
