ws2 install
    ws2 install
    if i buy a ws2 catback system how difficult would the install be... does it require welding.. or can it be done in a driveway
    from f22 to H22. still love the cb7.
    yeah do it in a driveway ...its easy..put in on then drive to a local shop and have them weld the joints...when you do it get new hangers they r only a few dollars at the parts store....
      The system is a full bolt on. Welding isn't required as they give you gaskets. The only trouble I ran into was the Cat bolts were seized and I had to have my uncle torch them off for me. However since you're in FL i don't think that'll be as much of an issue for you since my bolts were rusted.
        i bought a new cat to deal with that . . . haha, i should have just had them torched out . . . but i fucked up the flange pretty bad trying to cut them off with a die grinder then drill them out
        -Mark-
        CB7
        CD5
        And if i could swim I'd swim out to you in the ocean
        Swim out to where you were floating in the dark.
          I put my WS2 in about 45 minutes, counting dealing with the stubourne cat bolts.
          Go for it! *Thumbs Up!*
          - Zipcreature
          Awesome!
          CB7. F22A. 5spd. CB7. Exedy. Chromoly. AEM. DCSports. Apexi. Progress Group. AGX. Suspension Techniques. Viberant. Goodridge. Facebook
            The hardest part is the cat bolts if they are rusted... if you use Vicegrips (if you cant get them off) you should be ok. its not a hard job at all took me not long in the rain, I wanted it on the car.
            **My CB7 has been sold**
              Spray some rust penatrator on the bolt and then try to remove it. If the head is messed up then go to sears and purchase a set of craftsman easy out bolt removers
                its easy, easier with someone to help hold the pipes! i took pics of my install if itll help
                FA1
                355
                  My bolts were rusted too, I used a breaker bar and a six of beer in the end I got it off, felt good about it and my knuckles weren't too bloody
