wats up everyone. i am fucking tired of my auto, it shifts at 6500, so VTEC engages only from 5200 to 6500 and thats not enough. that pisses me off. i dont have enough money right now to switch it to manual. so i was curious if anyone knows IF i can get a chipped ECU somewhere. would greatly aprecciate any help. thanks.
h22 auto chipped ECU
What label does your tcu say?
If you have a jdm prelude tcu it would have something along the lines of "P19" on the serial. This should get ur car to shift at the higher point.
If you have a jdm accord sir h22a swap, the auto tcu with the label "PON" is going to limit ur redline to 6800. Check out a jdm accord cluster for a CD chassis, the autos weren't sports cars really so the redline is much lower. If you manage to find a prelude h22a auto tcu it'll set ur redline higher and u should be able to stay in v-tec longer.
If you are tired of it falling out of v-tec, u could get a v-tec controller and set ur hi>lo setting lower. Don't do anything too low i would stay about 4400-4300 at the lowest. I've been where u are but if you do the D1->D4 thing when racing, if you take it close to redline that way it's very unecessary if u can shift the auto correctly.
I have on my car is lo>hi 5200 hi>lo 4300. When just flooring it I can remain in v-tec without it just "tappin'" it. It's much easier to do with a v-afc but if you drive an auto manually alot u can achieve that skill and not fall out of v-tec. If your not quick, on the next shift, the car will drop back down to 4700-4800 right under the 5200rpm range u need to stay in it. You can even make your tires chirp which is cool!
Right now i've setteled on running a P12 tcu. It has shorter gearing than the accord tcu and gets me to 80mph in D3 unlike my a6 tcu which limits it to 70ish. I found this to be an improvement over the accord tcu I was using because it gets me off the line faster and i've noticed gas consumption is quite less. I'm in between this tcu and my jdm P0N tcu. I have no idea..it might because i have a 4ws p13 ecu and my jdm p19 is conflicting with it? There is 2 different P19 tcu's and I believe one was made for 2WS and one is 4WS.
I need a custom turbo manifold built....
707 NorCal NinjaZ
Honda Twincam Motorwerkz?"I am the Yakuza CB7!"'92 Accord Sedan SiR
