The F22 bore is 85mm, the H23 bore is 87mm, the H22 head is 87mm...
H22 sleeves suck for boost, the F22 will survive better. What about the H23 sleeves? Are they same as the F material wise?
H22 bottom end is strong enough for some mild boost. Will the H22 bottom end fit in the H23 block? I know the stroke is about 4mm shorter... what about crank journals, etc?
The H22 crank & rods will lower compressions even further in the H23 block, but pistons will be needed anyway, so if compression is too low, I can bring it back with pistons...
I want to boost up to the point where I won't need to resleeve the block. Aftermarket pistons and/or rods won't break the bank. Pistons, rods and new sleeves will.
The thing that bothers me about the F22 block is the bore difference, I'd rather match those up.
