p28 whoa's on boost
    p28 whoa's on boost
    Can anyone tell me the p28 is good for gettin rid of the knock sensor period or just temporarily disabling it. On top of that what will happen if i get rid of that little black box under the intake manifold while im using a p28 becuase i think its been damaged for a long time.
    it'll get rid of the ks and the iabs, which is controlled by that black box under the intake manifold when wired up correctly. obviously, you'll need a chipped / reprogrammed p28 to run the H22, whether N/A or boosted.
    5.6L V8 32V DOHC
    JDM HERITAGE - US BUILT
      i have a hondata s200b p28 is that good enough not sure if its chipped, is that okay
        Im just curious I was looking into chipped ECU, isnt the knock sensor a good thing to have. Or are you all deleting it to ease wiring.
          the ks is only one wire not a big deal. all it does is retard timing when your engine has a backfire. removing it with uberdata isnt a big deal...
            Your p28 is already chipped.
              I wanna know more about that damn blackbox the iab's will they have anything to do with my shit.
                O yeah that you dont need. Steve didnt even sen me mine with the motor, but i ended up getting one from midnight.
                You just have to jump the hoses so that the iabs stay open.
                  Black box is part of the IAB, its called the IAB Control Solenoid Valve. My friend wired up his IAB to open up when the vtec turned on. Its now sounds like a b16 or b18c5 when vtec hits. Just tap into the vtec wire. If you have Hondata, you can turn off the knock sensor so you stop getting that code 23.
                  Carlos
                  My Members Ride Page
