i don't know what the problem is but when i first start my car and drive it for about 10-20secs the car will stutter when i press on the gas and bog down. but after the few seconds of jerking back and forth it starts to drive normally. i changed the injectors thinking one or two might not be working correctly but the problem still exists. can anybody tell me what might be wrong??? fuel pump or bad fuel filter? any ideas? the black valve on the back of the firewall isn't hooked up but my car is mannual now so i don't think i need it or do i?
HELP PLEASE!! vaccum line valve?
Sounds like you might have a vacuum leak or possibly your ignitor is going bad. Check all your major vacuum lines going to/from the intake manifold and make sure the hoses are still somewhat pliable. You should typically let your car warm up just a little anyway, at least I do."Once a CB7 Tuner, Always a CB7 Tuner"
Former h23 swapped accord owner...
2002 Acura 3.2CL
20" Rims and Brembo Brake Kit - Ridin classy and slow
1994 MKIV TT Supra
BPU+++ (under the knife, getting nastier)
im gona say dirty fuel filter.H22 Prelude VTEC 92-96 200 161 10.6:1 87 90 DOHC VTEC 2157 JDM
Originally posted by Backfire32i don't know what it is still but good ideas on what might be worng, im just livin with the problem for now, its only like 15 secs of hell then notin but smooth crusin from then on. thanx for the help peeps5.6L V8 32V DOHC
JDM HERITAGE - US BUILT
