How much faster is an H23 compared to a F22a1? Is it really worth the swap if I just want a bit more power and quicker pick-up?, or should I just do a a6 manifold swap with new headgasket and timing belt and be happy with it?
H23 vs. F22 vs. SHUT UP!!!
why not put the h23a head on the f22a? ... shameless plug hahahah you'll retain your iron sleeves.. u wont have to pull the motor (makes it easier on newbies) and u have the tuneability & better capabilites of a twin cam head (it flows more than a f22a head).. not to mention the intake manifold/throttle body are bigger than f22a componets.. oh and if ur into that whole stock look ur stock exhaust manifold will bolt up to the head..
Praise The Lowered...
Originally posted by WiKKeDV16why not put the h23a head on the f22a? ... shameless plug hahahah you'll retain your iron sleeves.. u wont have to pull the motor (makes it easier on newbies) and u have the tuneability & better capabilites of a twin cam head (it flows more than a f22a head).. not to mention the intake manifold/throttle body are bigger than f22a componets.. oh and if ur into that whole stock look ur stock exhaust manifold will bolt up to the head..
Couldn't of been done without you guys
well if u had the intention of buying it from waga.. then by all means be my guest.. good guy.. but.. if ur asking this question.. then that also allows me to believe ur not to keen on car mechanics and shit only these lines because if u were ud know the difference off the bat between these two motors..
85mm vs 87mm
sohc vs dohc
etc
Originally posted by WiKKeDV16well if u had the intention of buying it from waga.. then by all means be my guest.. good guy.. but.. if ur asking this question.. then that also allows me to believe ur not to keen on car mechanics and shit only these lines because if u were ud know the difference off the bat between these two motors..
85mm vs 87mm
sohc vs dohc
etcI hate thieves!
Yes...all are noticeable differences and worth the swap. You need to decide on what your futur goals are. If you are just looking for another engine then swap the h23 for the low end tq. I loved it before I decided to head swap."This is a jaded bunch. To gain notice, you have to challenge conventional wisdom, test assumptions, and ignore the naysayers."
FS Part out thread koni/skunk2 suspension, jdm pole, HID retrofit, Tanabe exhaust
your block wont crack it will be your rings that will go bad before anything else..H22 Prelude VTEC 92-96 200 161 10.6:1 87 90 DOHC VTEC 2157 JDM
^ yeah, what he said...lol.
im about to block post my extra block and i got a set of custom pistons on the way with rings, etc.
but as for the choice i say.... if u are a tuner like must of us, and do modifications for yourself and the respect of others, go with the head swap....to get mad props, but if your not to concern about all that and just wanna swap and call it a day, get the whole h23 motorNEED RAP BEATS.....
www.soundclick.com/akcidentaltrakz
head swap head swap head swap .........trying to brain wash .....lol the swap is worth it i wouldnt take nothing for my F22/H22F22A1:blew up
F22A1/H22:blew up
F22A6/H22: " "
F22A4/H22: " "
H23A1 boosted:blew up
H23A1:traded
H23A1/H22 built:still in progress (getting my feet wet)
drive it like you stole it
FCB7(FRANKENSTEIN CB7 CLUB)
What modification is needed to do the headswap?ProjectParty.net
Putting an end to the question, "What's going on tonight?"
"This generation has this universal sense of failure" - Kurt D. Cobain
CLUB 1320
My FOR SALE thread...buy my ish
Originally posted by i_love_cb7hummmmmmm...... turbo.......................
should I be the official the turbo whore???
-Henry
