I just traded for a jet v force. all you do is plug it into your tps and map input and output signal. any one else used one. i put on and imo noticed gains. it's not like those shitty ebay resistors.
jet v force
i ran one on mine w/ the f22b, i liked it. it started giveing me CEL for the map sensor. i took it off and never had a problem . i had it warrantied by jet, sold it to a buddy, he's had it installed for about 6 months now and loves it. i caused mine to run a little warmer, but that because it leans out the fuel. more o2 + less fuel = more power = more heat generated.Last edited by souldoubt; 03-21-2005, 12:49 PM.
It just simply makes ur ecu think its in higher vac than it is. The higher the vac the higher the timing and lower amounts of fuel are being injected. Its moreso the added timing than the difference in fuel.Knowledge is power...in EVERY sense of the word
