What parts would be needed for 20psi engine build
    sometime this upcoming summer im planning on building an f22a turbo machine.
    heres what im thinking. the f22b dohc head on f22a6 block bored to at least 2.4 liters. I plan on getting a small enough turbo to spool at almost idle or idle (1500) rpms. my main goal is to build a torque monster, one that could compare to the v8 punch that is felt off the line. For the build exactly what parts am i going to need. i have a general idea but i need an exact list.
    Also what horsepower and torque will i be looking at. my goal is over 240 torque. thanks david
    Edit: also what prices am i looking at
    any small turbo will be pointless.
    look at some compressor maps, you need something that flows alot of cfm's, and that's gonna be a pretty big turbo.
      well that'd be if he wanted the high hp but he's going for low-end torque. And at 20psi i'm more than sure he can hit that even on a small turbo...it might be at like 4000rpm and be at like 160hp by redline but still lol. If ur boring to 2.4 liters i would think u'd want to look into sleeving unless u plan to somehow stroke the crank or whatever. You'll also want to think about investing in head bolts, engine management, a hotter ignition system, and of course forged rods and pistons.
      Food for thought...i have a t3/t04e that creeps into positive manifold pressure by about 1700rpm in a 4th gear pull. Full boost by 3200rpm...kick in the face a bit before 4000rpm. What i'm trying to say is just because the turbo is spooled and ur at a high psi low in the rpm range doesn't mean your making much power down there still. U gotta do compressor map calculations and pick a turbo that has max. efficiency at the rpm range u want.
        im in the middle of hooking up my f22a/b hybrid for prob about 14 psi this summer...im going withthe forged internals and all that good shit. I also have some turbos for sale, on huge one from a 6.5liter v8, that would def be able to give you 20 psi, also a definate kick in the pants! I also have a t3 which has been a fairly decent size for a 4 banger...as far as u looking for such a small turbo that will spool at idle, i dont have nothing for ya, but when i did have a turbo on my car last summer i was running an ihi rhb5 and it spooled as fast as i could put the petal to the floor with almost no lag...
        My baby laying down some power...
        http://www.youtube.com/watch?v=kd_Q8HSIyqA
