Originally posted by CB7Nub
View Post
Increase F22A Top Speed
This topic is closed.
Accord SE
93se
Members Ride
Bought from: H22wagon93, Theos92VR4, Hondafan81, Father Time, DarkHusk, Gunrunner, FamousFreak
Sold to: sulimed, BurtonRiderT6, tishock
Our accords have a good fast automatic tranny but a manual is faster.
Maybe your friend didn't know how to drive if he was almost beat by a automatic
My ex with a automatic can beat a stock 5 speed even one with a h23 tranny.But it has a stage 2 cam and a good exhaust and a short ram intake.
Auto's usually have slower top speeds and less top end power vs manual (with same car/engine combo)
Auto's do however shift faster/smoother and typically take off better than their manual counterpart.
after all an auto is not being directly driven by the engine like a manual...but it IS always engaged even in gear at a stop...unlike the manual...and at low rpm the auto has some crazy torque multiplication going on...but once you get the engine over 2000rpm the manual will perform better.
But all this is beside the point...let me add emphasis to what deev said...
doesn't matter if you are driving a 20year old family sedan or a brand new ferarri...going 100+ mph on ANY road is dangerous...a track is the ONLY road that is LESS dangerous...but is still dangerous. I asked this question once and you most likely meant how can you safely get it fastER...not how do I get my car to go 200mph....but there is a difference in those two questions.
no lowering springs is rule #1 the lowest you should go pricewise is the super cup kit...after that you would want QUALITY NO CHEAPING OUT struts and springs...all new bushings...all new ball joints...pretty much you need to overhaul but mostly also UPGRADE the ENTIRE suspension. This will help your handling and make you less likely to cause a wreck.
something else to consider...your steering system was designed for speed limit travel...while you may think removing the p/s pump would solve this...the p/s pump does not operate at high engine speeds...I am talking about the gearing. moving your steering wheel just 1/2 inch at 60 will have far different results than 1/2 inch at 100+ Again...the entire car is NOT made to go over 90 really.
Then you can get into bookoo's of engine mods and tranny mods...basically increasing power, changing gearing...using a tranny with a different gearing from another car...those can also help get you faster. Be it the time it takes you to get to 90 is shorter or that you can reach higher speeds...either way...faster.
but also ask this...WHY? What is the point of "going faster" Theoretically you should reach your destination in half the time by going 120 instead of 60...if you had a 20 mile stretch you would theoretically reach it in 13 min going 90 and 17min going 70 and 10min going 120. But that is in theory...in reality my 20 mile stretch of interstate...going 80 vs 60...I make it accross that in 2 minutes less going 80. Why? Theoretically I should have traversed that stretch 5 minutes faster...Cause there is traffic. When I go 65 though...I NEVER have to slow down or go around people...that is niiiice.
So 20mph faster saved you THEORETICALLY 4 minutes...wow...but how much more gas did you waste? The resistance from air just goes up and up exponentially as you speed up so you saved 4 min but wasted a few more mpg. I usually get 27 mpg...I have been driving 60-65 EVERYWHERE and I just figured where I am at and I am getting 30mpg...and my gas light has not even come on yet. I usually only get MAYBE just under 200 miles on 7 gallons...I am at 210 and no light and still got a bit left too. So I was able to go more than 10 miles furthur by going 20mph slower...think about that.
And there are folks who have spent thousands of dollars upgrading the cam, ecu's, fuel pumps...etc etc...everything BUT the pistons...and are at 170-180 hp...so even spending thousands of dollars you will NOT be much faster AT ALL.
So you will not win any races, you won't get to your destination significantly faster, you will GREATLY waste WAY more gas, and you are at a MUCH MUCH greater risk of tickets and accidents and death...for you and others.
So you can see why this question gets such a negative response usually, it is so pointless it is stupid to go fast...you do nothing but endanger everyone and waste your own money.
Short answer...if you want a fast car...buy a fast car...drive family sedans like a family sedan...you can make it a LITTLE better...but not much...because what it takes to MAKE a car fast is far more than folks realize.Last edited by bcjammerx; 05-30-2011, 03:36 AM.____
skip to the 1 minute part
and disregard the fact that it is a daewoo, its still a newer car, built to meet newer standards of safety
i dont care how well you have rebuilt your suspension, or modded your motor/tranny, allways remember the faster you go, the faster things occurLast edited by KB7; 05-30-2011, 08:46 AM._
I got to about 127 in my first CB, before all my big upgrades
But yea regularly testing top speed = easy way to kill yourself and others, don't be a bonehead
I can bullshit on that daewoo, it did a terrible job in the 50mph crash.
Regardless im just asuming the people in here should be smart enough to know when you shouldn't go any faster because your car is a piece of shit and might fall apart
And that you shouldn't do it with other cars on the road because they can pull infront of you at any moment.
Yeah i've done some really stupid stuff in the past and this is exactly what i learned, thankfully i didn't get into an accidents because im sure some serious shit would have happend ( although i was in a car ALOT safer then any cb7 could wish to be )
Originally posted by bcjammerx View PostWhat is the point of "going faster"
That is the stupidest thing I have heard all day but then Aegean I just got out of bed.
I am not even going to argue that because I know everyone here wants to " go faster" The whole point of most of this site is to make our cars fasterLast edited by thepowderblue; 05-30-2011, 05:51 PM.
acceleration vs top speed
there is a big difference between acceleration and top speed.
I will also state that if that is the dumbest thing you have heard all day, then this is the dumbest thread made on the forum.
You just said yourself that 90 percent of the forum is for going faster... so why the hell do people make a thread asking what do i have to do to go faster.
READ!
