okay i just rebuilt my motor and its smoking like a pot head. the motor is an h23 block sleeved and bored to 88mm. and the head is from an h22. i replaced the valve stem seals and everything on the head. and i have good compression. the only thing i can think of is the rings being the wrong size. the pistons are 87.5mm and i think i may have ordered 87mm rings. but the bore on the block is 88mm. could the pistons be just a tad bit too small for the bore size or is that about right? i need a lil help on this one pls. if you need more info just let me kno. im a lil upset so i may have left something out thanks
turbo build smoking really bad
stop driving this car if you are...go ahead and tear that engine back down...who built this engineNew paint job and bumper 8/8/11
tsx retrofit
f22b dohc boosted
custom gauges pods
Motivation is one of the keys to life....tell me "can't" and I wll show you I can
Originally posted by lildeez07 View Postokay i just rebuilt my motor and its smoking like a pot head. the motor is an h23 block sleeved and bored to 88mm. and the head is from an h22. i replaced the valve stem seals and everything on the head. and i have good compression. the only thing i can think of is the rings being the wrong size. the pistons are 87.5mm and i think i may have ordered 87mm rings. but the bore on the block is 88mm. could the pistons be just a tad bit too small for the bore size or is that about right? i need a lil help on this one pls. if you need more info just let me kno. im a lil upset so i may have left something out thanks
block is 88mm so u use 88mm pistons and rings............
Yeah..see if you can sell those pistons who have now...to make some money back...when you buy the 88mm pistons you wouldn't have to put out to muchNew paint job and bumper 8/8/11
tsx retrofit
f22b dohc boosted
custom gauges pods
Originally posted by 92smokeaccord View Posthe said he built it....
normally means it got sent into the shop to do so.
when he built it, he meant he just added the head.(assuming)
yah whoever you got the block from screwed ya.
when purchasing you gotta be very weary about who you get your stuff from.
all items should match. good luck man. sorry to hear, will be a nice build once you recover from this tho,
Just keep positive.
This is so much fail on someones part....... You never bore a block without having the pistons on site. A good machine shop will measure & bore the cylinders out to fit each piston individualy. This is just in case there is a fraction of a difference in piston diameter between the 4.
Your cheapest bet will be to measure the bore and buy the next size up piston. That way the engine shop will be able to match the bore to each piston as it should be. If you get lucky the 88mm sleeves may work with a set of 88mm pistons. depends on the clearance that the bore has been given for said pistons though.
^^^^what this guy saidNew paint job and bumper 8/8/11
tsx retrofit
f22b dohc boosted
custom gauges pods
