Im buying a real nice low mile F20a and for smog purposes i need to place the internals in my old F22a4. The crank bearings are the same right? Either that or i want to put the higher compression pistons in the F22 for a rebuild since they are the same bore.
F20A Inside F22A4?
Originally posted by CB7Man View PostIm buying a real nice low mile F20a and for smog purposes i need to place the internals in my old F22a4. The crank bearings are the same right? Either that or i want to put the higher compression pistons in the F22 for a rebuild since they are the same bore.
My 5.7 LS1 Holden Ute
i honestly dont think you check for block identification during a smog check. hell you could probabl have a f22b1 vtec and just shave the valve cover and the smog tech wouldnt notice. at least i wouldnt notice, lol.
Anyways...Everything will swap right in, make sure your a4 bores arent too big otherwise you WILL need a oversize piston.
Originally posted by CB7Man View PostWell I went nitty gritty and the engine blocks and bearings are identical.
Originally posted by wed3k View PostAnyways...Everything will swap right in
Oh and does that account for the shorter F20 rods?Last edited by evil_demon_01; 09-30-2010, 04:50 AM.
Originally posted by Sarthos View PostIsn't it basically just a destroked F22 with higher comp? In which case couldn't you run the F20 crank with the longer F22 rods and the higher comp pistons to get a really high reving engine?
Its a sohc f20
Originally posted by wed3k View Postrunt he f20 rod and f20 crank. otherwise you'll have issues with deck clearance.
like my project with running a h22 piston with f22 rods, im going to end up with the piston .040 out of the hole.
I have access to an f20c block....can i use anything?
All done
F20a inside a F22A1 block
Amazing, the engine block had 280,000 miles and the bore at its largest point was .002 out of spec.
Pistons were the same AABA
All rods bearins were within specs 1.2~1.5
Main bearings were mostly the same asside from 1 being smaller. But it was wore in to specs. These bothered me because they were getting close to outside specs 1.8~2.1
Talked to a rebuilder and he likes to run 2.5 on mains. Owell
Wow a year later and results are in
Looking clean bro congrats on your successful build
Originally posted by deevergote.......If they seem smart, and just trying to learn, I'll offer as much help as possible. If they seem stupid and lazy, I'll do my best to piss them off so they leave and never come back... while still answering the question.
