Can you say....DYNO
    Originally posted by Maple50175
    Accord R33 I wanna boost my car.. Can you help me do it?
    of course
      Originally posted by Accord R33
      absoluty, i agree 100%. it was that RENR guy that said he cracked a rod. he definitly wansnt blaming it on you in anyway though, he seemed cool about it. i was just letting you know. im gonna try and check my timing today or tommorow to see where it is at. just let me know where abouts its should be. thanks.
      well...thats the thing...umm i'm not sure exactly how u could check the cam timing. I mean i don't think u can check to see if the cam is off by a degree or 2 just by looking at it under the timing light. Has the timing belt ever been replaced? Cause the belt could be off by like a tooth. Or maybe your map just gets retarded after that point?
      A cracked rod would have to do more with age and structural integrity of the internals. Possibly even making too much power or overboosting could cause it but not detonation.
        excellent video, bro. wtg better watch out in about a month
        did they tune it for you? or did you do it yourself. btw guys i'm curious how this will apply to my setup being dohc. would you be interested in sharing the map?
        I hate thieves!
          hey R33...
          so hows the car now....meant to ask u...
          do u feel that extra 19-20hp u got???
          NEED RAP BEATS.....
          www.soundclick.com/akcidentaltrakz
            Originally posted by theone
            hey R33...
            well like i told antoine. Before the dyno i could never punch it in 2nd when the ground was wet because it would just spin tires and i would go nowhere.......now.....i cant do it on dry ground either
              Awesome numbers. And yeah, I'm interested in the DOHC. I think with a 14b tuned pretty good, the numbers will be like 250 whp, and a crazy amount of torque.
              Shift_BOOST
              BOOM!
                i highly doubt you'll get to 250, especiallly with a 14b. too small of a turbo to make that much whp
                  only way to find out is to try. If only I had my turbo kit right now...
                  Shift_BOOST
                  BOOM!
                    great vid man car looks great. keep doin ur thing love the car
                    7TH SIGN
                    BUDDAHA"S FAMILY
                    FREE T.E.M.P.O
                      we'll see bro, we'll see.
                      I hate thieves!
                        good dyno i'm ready to put mines on it's the same as yours but i'll be using smic and t25 instead of the 14b and some different changes to the head mani and the exhaust.
                        but good numbers on the dyno
                        i hope to put down 215whp with my setup
                        no using any base maps using 92 intergra ls ecu and chipped that
                        and afc controller can't wait
                        H23vtec
                        Kee Built/Tuned
                        87x95 11.7 compression, custom h22 intake, minor head port polished, 70mm tb, 3inch cold air/3inch vstack, stock cams,ebay header with 3inch collector,3inch exhaust.
                        9.0's at 81mph in the 1/8th mile ohh how i miss my baby.
                          hahah trust me dawg 250 is easy to get with 14b dohc you just need to really tune it good
                          homboi with t25 n safc put down 270 with t25 turbo which is smaller dan 14b
                            why are you going to use a chipped ECU and an AFC together? there is no need.
                            but good luck with the setup..
                              I got a question about the civic ecu. I think you said your using the p05, but I can't remember. Anyway, I'm gonna be using a p06, but does everything wire up the same as the stock ecu? I remember asking about the IAB for the p06, and someone said to run the vacuum line somewhere... I have to go search for that again.
                              Shift_BOOST
                              BOOM!
                                yes im using a p05. A p06 will plug right in, the only that that you need to do different is check the "disable o2 heater" box under the misc. tab of uberdata if you are using a p05.
                                neither the p05 or p06 can controll IABs. you need a p72 for that
