put her back together last night and took her out for a test drive.
made it down the driveway fine, onto the street...
1st gear....fine til i try to get on it...WTH
rpm stoped at 3500 (just like when im using my full throttle launch)
2nd gear, starts fine......then same results, ok somethings up.
go back home pop the hood, speed sensor wasnt connected all the way, connect that.
go back out....
cars driving fine. get on it a lil and the clutch seems to be grapping pretty well. (in 3rd & 4th gear)
turn back around and go down the highway back towards home.
get on it semi hard in 1st gear.....the back of the car dips down and front raises..... , smash into 2nd....spin, then hook up, front raises again....at this point im like HELL YEAH ...lol
then i let off it, park the car, and go in the house happy .
all in all, the clutch/FW was a great mod, hell of a lot more power getting to the ground now. (all i need now are stronger axles.)
i still wanna just drive it around the block a few times to see how she does, make sure everythings ok ( i think the coolant issues fixed also).
only thing...my clutch pedal is spongy as hell, the clutch works fine but my clutch pedal is not STIFF. but when i turn the car off, it stiffs up just fine, like normal.
i bleed the system but i did italone, with no one holding the pedal down while i bleed it, i just had 2-25lb wieghts trying there best to hold it in place, so it might be that i need to re-bleed it
go back out....
