If someone took a stock H22 block, and asked them to bore the FRM sleeves out to 87.25mm from the stock 87.00mm, would there be a problem? If this isn't possible, and someone wanted to run the 87.25mm 11.5:1 comp. Mahle pistons, would they have to get the block resleeved? Basically can the FRM sleeves be bored to 87.25mm on the H's, and be used correctly?
Boring out FRM sleeves...
