taking away fuel for power
    to a point running lean will add power... but what bad can happen if you try and run too lean?
    whats the highest you can run and still be safe?
    i was looking over all my graphs and previous runs had a 5hp gain in the midrange because it was running more lean.
    at 5600, one runs afr was at 13.42 producing 154.02whp. and another was at 14.17 making an even 159. is there any sideaffect to running leaner?
    lots, incredibly high combustion temperatures to start out with, pinging and detonation. You can blow a motor very fast running too lean. The key is to run as lean as possible, without risking ANY pinging, detonation or otherwise. You can run a little leaner at the track than around town. Best way to tune for this, is obviously on the dyno
    - Nathan
    Nathan Morris
    92 Accord LX - RIP
    92 Civic CX B18B1 Hatch - RIP (126whp, i/h motor)
    99 Civic EX Coupe w/ 1.9L stroker on the way, current at 121whp.
    nonVTEC.com - Technical discussion for F, D, and H series nonVTEC tuners
    H22Power.com
      TRU-dat
        does the safe range change depending on what you have done to the car?
        whats the leanest you can run and stay safe?
        all i have are cams so it should be much different than stock.
          I tried with mine by tinkerin with the aftermarket fpr tunning by wo psi down and up from stock
