ebay header instal
    ebay header instal
    Hi guys im kinda in a jam while trying to instal a aftermarket header on my 91 ex with "AC" it seems that the ac hose is in the way......dose this have to come off? thanks
    probably if you pull off the header from the bottom you wont have to worry about that.
    Retro!
    Hater
      Just delicately flex it out of the way. You shouldn't have to move it much to get your header in there. If you disconnect it you're violating some EPA laws and could cause a serious freeze burn from the temperature of the refrigerant that's coming out. I don't know that you can fit the header up from the bottom as previously mentioned, but you can try.
        The aluminium flange and pipe that connect into the flexible hose ARE in the way
        You WILL have to remove that flange/pipe to install the header
        What i did was refabricate the flange so the pipe exit was on an angle, which with the hose attatched misses the header by about 20mm
        You could do the same, or just lose your AC.. I'm Aussie, AC isn't optional
        Built & Boosted.
          Have fun gettin those downpipe nuts on the header!
            post up a pick when done the install
            92 Accord EX - SOLD
            PSN: REDxMAN-_-
            MR===>http://www.cb7tuner.com/vbb/showthread.php?t=146478
              put some wd40 or pb blaster on it. For me it wasnt hard at all to take them off, a long extention from the bottom did it.
              Retro!
              Hater
                The problem with my old ebay header is that I couldnt get to the down pipe bolts at all. I bought a Ractive header and it fits ALOT better. Still not perfect but its a hell of a lot better than ebay junk.
