Torque mount insert
    Torque mount insert
    Is it me or was there a DIY on how to use the energy suspension moroe mount on an automatic car. Where'd it go?
    its just you
    i kid... is it the front motor mount your talking about? If so its just a 17mm bolt. The wrench (with u facing towards the car) should be on the left side of the mount..if u try to untorque the other side you'll be there till ur fifty-two. Push the inserts in, put the bolt back in and your done
      Thanks for responding, I know how to do it, it's just that my car is an automatic and the inserts are for manual only. I remember there being a DIY where the guy cut the inserts to make them fit. That's what I need to know. What part to cut
        Yeah they don't fit right in auto's. Check in DIY's for motor mount inserts. I wedged them in using some oil to make it slip in, then tightened it down with a bolt. I think you're better off buying a new dogbone, because those mounts were intended for manual trans. mounts.
          Yea I remember there being a DIY but it's gone now
            Hmmmm, you appear to be correct...I don't know what they did to it
              Ok heres what I did
              I found what I thought was a DIY from this site on Accord Tuner: Here it ishttp://board.accordtuner.com/showthread.php?t=6962
              The guy cuts into the inserts so that they fit over the automatic mounts. It doesn't require that much cutting, the mounts are almost exactly the same. However since I was able to snag a manual mount I just but the inserts into that and installed it in my automatic car. That mount was in pieces but as soon as I find a good one, auto or manual, I'll install that one with the inserts.
              My first inpressions are that they are working, I am noticing the vibrations that everyone is talking about, I however think that this can be fixed by inserting something between the inserts and the bracket. It'll have to be something thin
                yeah its still here. search. lol
                what about for the back motor mount inserts. is there such thing
