74 to 68 mm tb on stock h22a
    Hello, I was just wondering if you guys though I would loose too much performance running a 74 tapered to 68 mm tb on a stock internal h22a.
    H22a
    Euro-R IM.
    RDX Injectors
    Bisi Intake gasket.
    Stock JDM Header
    60mm Cat back.
    Chipped p28
    I will be running the Bisimoto h22 header in the near future.... assuming the group buy happens.
    I am aware of people who have had issues with too large of tb, but I haven't seen the issue be prevalent with h22's
    Let me know what you think.
    201 Whp H22a with bolt ons, see the progress from stock f22a to now HERE
    im running one with mine. only diffenance is i have pro1 cams. seems fine to me.
      well I have a h23a dohc vtec and it comes stock with 68mm tb but didnt have a Idle air adjustable screw valve so I swat it to a h22a tb and I noticed a big diffrerence! a bad diffrerence lol. its slower no at take off I beleive...I am putting my stock one back on
        its 65mm not 68mm
        Just do what PR CB7 said.
          Tuned
          My first question to you is if it has been tuned since the TB has been installed, If not and you are still running stock map and stock tip in fuel then yes I would imagine it is much slower at low rpm's
          EDIT: I read your post wrong, I read that the bigger tb made it worse, instead of the stock one. Thanks for the input!
            Bump
            Bump, in case anyone has any additional input.
              im pretty sure, if you get at least a ebay header you'll see some gains
              195whp gains, i know it maybe a lot, but, you have almost all of the intake part taken care already
              stock JDM header will limit that engine, mostly because of the downpipe
                Header size
                The jdm header is actually pretty good. I would compare it to a cheap ebay header in terms of flow, and much better in quality. I agree I need a new header, but I am not going to get one until either the bisi group buy or until its gains have been shown.
                  H22's love big TB's. Bore out the manifold to around 70mm if you can.
                  Current 2016 Ford F150 XLT Sport
                  Past 1990 Accord EX Sedan
                  Past 1990 Accord LX Sedan
                  Past 1991 Accord LX Sedan
                  Past 1993 Accord LX Wagon
                  Current 1991 Accord EX Wagon
                    Manifold
                    The manifold will be bored to 68mm. Rosco and I discussed 70 and he said that If I am planning on running IACV to only do 68mm. He has never used the Polar Bear tuning 74-68 before so I am going to get it and let him see it.
