So would it work just putting it into my lx or would I need to modify anything? At what speed does the governer kick in on the ex?
chips, what u guys think
I personally don't like most chips on ebay,because you have no real idea of what program your really getting and they disable most of you sensors and have either a high rev limiter or no rev limiter at all. Also some programs are for race motor that have high compression and altered fuel and ignition curves that are not matched to our specific application which in 95% of the time are street application. I would just get a program burned to your specific application.
F/S:Pioneer Premier Deh-880prs w/ ipod adapter $220
The US EX ECU speed limiter kick in at 130mph the JDM/UDM EX ECU for the F22A go up to 140mph.
any cheap chip out there that can disable the speed limiter?? my lx-ex ecu swap is not cutting it anymore, with my new light weight 17" and turbo I'm hitting the speed limiter alot while the engine has alot more power to go..
maybe adding a resister in the stock ecu would do the trick any1 know..90 Accord Coupe LX, Stock JDM H22A Engine 10.6:1 - Stock Automatic LSD MPA1 Trans, JDM P13 Auto ECU + JDM P19 TCU. Tune with Greddy E-Manage Ultimate
< 317WHP/227WTQ@11psi> B/W S256 turbo, Daily Driving on 93 pump gas - since 2006. Driving Turbocharged CB7 Accord since 2002.
