I just changed oil and switched from Amsoil synthetic filter to a Royal Purple synthetic filter and wanted to post up one major observation.
6,000 miles ago when I first switch from Purolator PureOne to the Amsoil I noticed my oil light always blinked at me once right after startup when the engine had been sitting for 1.5hrs or more. (this was something new)
I did a bit of research and found quite a few complaints about the Amsoil anti-drainback seals performing poorly and allowing oil to drain back out of the oil passages after shutoff and hence the second of low oil pressure on startup I was seeing. My oil light was EXTREMELY consistent in that it would ALWAYS blink at me once immediately after startup when the engine had been sitting for 1.5+ hrs.
I just changed the oil last week with a Royal Purple filter and the oil light magically no longer blinks at me, even after sitting overnight. The Purolator PureOne filters also never caused the oil light to blink either which leads me to believe that the Amsoil filters have inferior drain-back protection. If this is important to you, don't waste your money on Amsoil. FYI.
