Will H22 main studs interchange with F22 main studs ? I can't find any F22A1 ARP main studs and was wondering if the H22A1 mains studs would work for the F22A1
Will H22 F22 main studs interchange ???
look on ebay its called a mainstud kit cost about 130 shipped when i got mine a few months ago.Members Ride sold...
ARP sells a main and head stud kit for the H23 application that I know works with F22ax. I have both sets installed on my motor, I know it works.
It comes with moly lube that you put on the threads, screw studs in my hand with allen wrench snug. Then, make sure you torque each stud 4 times! Use the torque recommended with the provided paperwork that is for moly lube.
Torque to spec, then back off about 90 deg, then torque again. Do this a total of 4 times.
I did this and marked a reference line from stud to nut to engine block/head for each torque, you will notice you will get increased rotation with each torque. On the 4th time, it ended up at the same spot as 3rd torque, so you know it has reached proper torque. THIS IS KEY!!
Originally posted by HondaFan81 View PostARP sells a main and head stud kit for the H23 application that I know works with F22ax. I have both sets installed on my motor, I know it works.
