EGR vaLve???
    EGR vaLve???
    can the car operate with no EGR vaLve??
    praying for GUS and better days
    yeah. there are a lot of people who block it off and car still runs fine.
      wuts ways to bLock it off??
        http://www.cb7tuner.com/vbb/showthread.php?t=114863
        http://www.cb7tuner.com/vbb/showthread.php?t=117818
        http://www.cb7tuner.com/vbb/showthread.php?t=46831
        http://www.cb7tuner.com/vbb/showthread.php?t=29834
        Why is your "L" key stuck on caps lock?
          good Lo0ks.
          yes my L is stuck on caps it sux!
            attention to detaiL gotta Love it LoL
            Ride List
            1990 Accord dx coupe - my baby (dsm turbo set up in progress) http://www.cardomain.com/ride/3202853
            2005 Mazda 6s - daily driver http://www.cardomain.com/ride/3171724(totaled)
            newest 2006 mazdaspeed 6 http://www.cardomain.com/ride/4073987/2006-mazda-mazda6
              does the check engine Light come on wen its bad??
                it shouLd.
                  y'aLL are bogus..
                    yeah it should. its easy to replace but cost a little over 100 for a new one
                      The EGR vaLve onLy operates/opens when you are cruising. So yeah it wiLL work with out one
                      Why do you beLieve yours is bad?
                      wat?
                        how would you get the cel to not blink when you remove the egr valve, without switching ecu's and chipping.
                          without changing the ecu? take the check engine light out lol, i did for a while(not recommended)
                            I honestly thought about taking it out, because mine has always been blinking on for something, fast idle control, oxygen sensor, where my car sits on the ground, scraping, and i had another code but forgot what it was, been so long since i have driven it..
