are the 92 gsx turbo eclipse injectors the same (connection wise)
injectors
Originally posted by d112crzy View Postblack and blue tops use the same connector.
going with
h23 block-h22 piston heads
f22 head - pp
regrind cam
h23 IM double space-no butterflies
KS eliminator
underdrive pulley
p06 chip ecu
hoping 2 get some feedback on this cause i really wanted h22 345cc
your knowledge is greatly appreciated thanksClick here to see why my signature was deleted.
There is no such thing as too big of an injector. You could have 1600cc injectors and the only difference is that the duty cycle would be much much smaller than one of lets say 200cc. For a 200cc injector it would have a duty cycle of about 90% just to put as much fuel into your car as a 1600cc injector would at 11.2% duty.
The bigger the injector the easier it is for more fuel to be added. It doesn't make adding less fuel any harder from what I understand. If I'm wrong please correct me someone.Been a long time. Still alive...
Originally posted by WilliamW View PostThere is no such thing as too big of an injector. You could have 1600cc injectors and the only difference is that the duty cycle would be much much smaller than one of lets say 200cc. For a 200cc injector it would have a duty cycle of about 90% just to put as much fuel into your car as a 1600cc injector would at 11.2% duty.
That said, 450cc injectors are fine but aren't optimal for the setup the OP intends to build. 330cc or the h22 345cc injectors are greatly preferred for NA setups normally. Read up on "atomization"Knowledge is power...in EVERY sense of the word
