Future engine build.
    ++/So I can't decide on what engine to build for N/A perfomance. I'm debating between 3 engines I want to build,so aybe you guy's can help me decide.
    The 1st. eng F22b1
    F23 Pnp Intake manifold w/H22 bored throttle body
    Stage 2 bisi cam w/ valve train
    Pnp intake and exhaust ports
    wiseco or mahle pistons and rods
    oem or acl bearing
    arp main and head studs
    balancer shaft delete kit
    high volume oil pump
    Chipped ecu w/ hondata s200
    Blox or AEM fuel rail
    11lb flywheel and stage 2 clutch
    If I calculated right I should be at 180-195 hp and 150-160 somethimg in tq with a good tune.
    2nd eng. H22
    PnP intake or Euro R intake
    Stage 2 cams w/ valvetrain brand don't know
    oem or acl bearing
    Calculated hp and tq with a good tune 220-240 hp and 180-200 tq or more
    8lb flywheel and stage 2 clutch
    3rd eng. F20b
    Have to research on performance parts since no one hasn't built one up yet.
    The f22b1 would be a sleeper,but the h22 and f20b would be for road race.
    d112crzy your advice is welcome
    NEW CB
    old Darkcloud : 1990 Accord EX MRT
    new
    DARKCLOUD : 90 ACCORD EX MRT
    There's actually quite a few f20b builds on h-t.
      I'll check it out,am I right with the hp and tq numbers or close to it or could more be pushed out.
      NEW CB
      new
        With the H22, expectations are a bit high and can differ a lot depending on which cams you decide to go with.
        I wouldn't waste my money on an oil pump, besides OEM. Also no fuel rails are needed.
          your torque numbers are wrong on the b1, the b1 is known to make around the same torque numbers as hp. i am at 140 on a b1 and i think with a port and high comp. with tune it will be capable of decent numbers but around what you are guessing
