h22a help
    h22a help
    how can i tell if it is a type s or just a h22a thanks
    The Race Car
    Type-S = red top
    H22a = black top (unless painted)
      so there is no outher way to tell
      The Race Car
        take out the cams and measure.... if its either a h22a or type s. Or if the cams are blueish then its type s. but then again you really can't tell from visual perspective outside. It could be a obd2 motor converted to obd1. To many variables... someone chime in please....
        either kill it or drift it...
        2002 Toyota Tundra V8
          plz help
          The Race Car
            Originally posted by beerman987 View Post
            plz help
            take a picture and post it. Take pics from all angles of the motor and then we can help you more. From seeing nothing I can't really help or anyone really.
              JDM motoes dont have letters after the numbers. I know blue tops are euro and red tops are jdm which doesnt matter because it could have been changed over! now the typs does have a bigger tb and intake mani than the regular h22 which is where im guessing the extra hp comes from. ooo and they come with lsd trannys if your buying the whole swap
                blue tops are only applicable to F20B DOHC VTEC and H23a DOHC VTEC.
                H22a are only black and red.
                H22aR/S can be differentiated externally from the red VC, different head stamp code (PDE), and in Euro R form, has a single runner IM.
                The Type S H22a still has the IAB runners. Oh, and both are OBD-II, so they have the single socket plug at the distributor.
                Click sig to view MR thread
                Links to other rides:
                Honda Accord Euro-R
                Honda Odyssey Absolute
                Honda City I-DSi
                Honda Stream
                  I have a type s motor and you can't tell the difference from just visual. You'll have to measure the cams and pistons.
                  People can easily change a regular h22a cover to a red one. All the 97 and up are obdII motors. Mine was converted to obdI
                    Both the Euro R and Type S should both have PDE stamped on the head. The regular H22A's should be stamped P13. I believe it's stamped right on the front of the head.
                      and my outh baby lowered
                      http://norfolk.craigslist.org/pts/1059117628.html
                      The Race Car
                        looks like an accord h22a to me.
                          im saying h22a, its automatic.
                          edit: i think the 3 in the beginning of the code means "accord" too.
                          OHIO CB7'S #11
                          SOLD
                          Members Ride DevlTuning
                            another way to see if its an accord h22a is that the map sensor is on the TB. the 92-96 prelude h22a had the map sensor on the firewall.
                              from the CL ad.
                              It's MAP sensor is on the TB. Its an Accord H22.
                              OHIO CB7'S #11
                              SOLD
