help asap
    help asap
    yo do cb7s have two timing belts or one
    One, the other one is your balance belt.
      so the cb7 has 2 belts ine is foe the oil pump and then the other is for the camshaft like in the you tube video. but that video was on a 98
        no. the balance shaft is supposed to help keep everything in order but isn't needed.
        You have ONE timing belt. That runs the oil pump, water pump, and camshaft off the crankshaft.
          technically the oil pump runs off the crankshaft and not the timing belt.
            One...
            2008 3.5SE Altima
            1992 EX Coupe-FAIL
