will this fitting work on our fuel rails??
    i was looking for an fittings for my fuel line and i came across this fitting for the civic...
    i was wondering if this will work on the banjo fitting on the cb fuel rail...
    OHIO CB7's
    My Ride
    MOD FUND: better if I could sell some of my stuff.
    Build Thread
    vouches: oneoffaccord, dep22build, 1993haccord, hostile, da9b16, brian91accord,93 Accord lx, kc8enb
    thats a pretty nice piece. and it should as long as the inner diameter is the same as our stock one.
    WTB: rightside jdm 1piece headlight or just glass.
      thats basically what im wanting to know before i spend $16 for nothing...
      OHIO CB7's
      My Ride
      Build Thread
        if its for a civic it will work. i really dont think honda would change banjo fittings for a civic and a accord
          ok thanks larry..i just didnt want to buy it and it not work and not be able to send it back...
          OHIO CB7's
          My Ride
          Build Thread
            and then that connects to a braided line right?
              x2 I bought a Civic SS fuel line kit with the banjo fittings and it fits perfect. You shouldn't ahe any problems with that fitting.
              Yes it connects via An -AN fitting to a braided line, I guess it doesn't have to be braided though. It could be a rubber line if you so choose the AN hose fittings will work on just rubber if the OD is correct. But who want's just plain old rubber with all those nice fit'ns
              MR Thread
              GhostAccord 2.4L Blog
              by Chappy, on Flickr
                sweet! thanks for all of the info...
                OHIO CB7's
                My Ride
                Build Thread
                  why do you need braided lines if your using a stock fuel rail?
                  instagram @mikeymeyagi
                    because it looks cooler.
                      im cleaning up the firewall and shaving most of the studs off that i really dont need.. i am going to an in-line fuel filter...
                      OHIO CB7's
                      My Ride
                      Build Thread
                        what about the FPR side? since that is just clamped on, is there anyway to run a -6an on that side? i was wondering this the other day. even when it gets to the hard line portion, its still just a honda clamp. is there a point when that hard line turns into a screw fitting? or would it have to be run all the way back to the pump/tank?
                        Originally posted by d112crzy
                        So you're throwing a bitch fit because some other girl at school has the same nail polish and skirt as you do?
                          there is a fitting you can bu that goes from a hard line to the an fittings.. you could possibly buy two and put one on the fpr and the other on the hardline.. just a thought...
                          OHIO CB7's
                          My Ride
                          Build Thread
