Does anyone here have access to Genuine Honda Manuals for Technical specs?
I've managed to get a OEM shop manual (not the normal shopmanual) but the construction and function one.
I was wondering about making a new thread (or adding to pre-existing threads) in Technical / Performance for these new specs specific to CB F series motors, However due to my area I only have the Japan and european specs.
Most noticable info is things like -
The F22 actually came with 3 different versions of camshafts.
F22 compression ratios were - 8.8, 8.9, and 9.8
Theres alot more detailed info I can add to this thread also - http://www.cb7tuner.com/vbb/showthread.php?t=41915
Like - For Inlet and Exhaust valves: Bevel diameter, overall length, valve lift.
Camshaft degree pictures.
Block - Bore pitch, block height, skirt depth.
Etc
I only have the info for F18, F20,F22 for European, KY and KQ models though.
Anyone here have genuine info for other models?
My Shop manual Part # is - 62SM410
Etc
